New to site...old to boost!
Do you use a Heat Exchanger for your air to water Intercooler?? If so where is it mounted? And where did you put the pump?
Also could you tell us where you got the Dark Exhaust wrap at?
Thanks and it looks really good!!
2.5 gallon aluminum tank mounted in the passenger fenderwheel....pump mounted to tank, HE mounted on radiator....will get pics tomorrow....
Autozone has the headderwrap..it is tan, then use the black sealer coat over that...looks real nice even in person.
Lookin good!!!
Hows about one of those powder doughnuts on the right fender???
That would be nice to see how you have it all set up............
" Do you dump your wastegates to atmosphere or back to the Turbo Exhaust out? "
Someone was telling me that they are CRAZY LOUD if they go to atmosphere and are not tied back into the Turbo exhaust out?
I am going to Autozone today to check out the wrap for my TT set up!
Thanks
Thanks
That someone was me! Haha! Seriously though looking good, I love how turbo engine compartments get so freakin crowded in a hurry. I love powdered donuts,mmmmm.
I have seen alot of guys running them to atmosphere is why I am asking. For a Street Strip deal the norm from what I have studied is to tie it back in. Guys say on the street they get SICK of the sound under normal street driving. 7-8 SECONDS at a time would be no big deal I would think..........
The wastegates are bled strainght to atmosphere....and yes they are loud usually...may do something about it later....got to see if the 38's are going to regulate boost down low enough for me 1st.
Made it to the Dyno a few weeks ago and had some DFI communication problems...pulled my hair out for 2 weeks and finally broke down and changing over to megasquirt II...pics of tonights work....
So you bought it un-assembled? Which vendor did you buy it from?
I found one that sells it un-assembled for $247.00
How much time will it take you to assemble it??
Here is the one I found. Is it the same one??
http://www.diyautotune.com/catalog/...gement-system-wpcb3-unassembled-kit-p-59.html
Exact same one....I also purchased the relay board and stimulator (test board), relay board cable and 12' wiring bundle.....less than 500$
Got my MS@ all put together...about 16hrs just on the board....also went ahead and wired in 3 bar map sensor instaead of the onboard 21psi unit.....knowing me I will need all of the 3 bar (30 psi!)
Hope to get it wired into the car on saturday.
Looking really good! I see you used a different style Map sensor than the one DIY sells. Are you getting all the tips and tricks on how to wire this stuff in from Matt or are you figuring it out on your own?
I already had the 3 bar from before....I also had installed the 21psi unit onto the board, which was pretty nifty how it went together.....I just cut the prongs, unbolted and unsoldered it.
The 3 bar uses 3 wires just as the 21 psi unit so I just solderd the wires directly to the board and ran the wires out the tubing hole...just going to mount the map sensor beside the MS2...found the wiring diagram for the 3 bar in the online megamanual.
Well you are making it look simple! I will be starting on mine very soon.
Sorry for the long hiatus....slowly been working on the car and finally got it up and running with the squirt and was able to get it to the dyno....was fighting a breakup but after about 6 hours on the dyno we found the culprit....the MSD distributor cap.....
Got some good tuning done and made some headway with power.....
I was on a friends Mustang Dyno (which is usually about 10-15% lower than a dynojet, atleast when loaded)
at 10psi the car made 710hp at the tires at 6100rpms unloaded ,670 loaded)
at 17 psi it made made 846 hp loaded
at 22psi made 980 loaded at 6500rpms and 900 torque at 5200
damn if the boost don't come on hard and fast, especially with the higher boost
was running possible winter blend of e-85 so we did not push it any harder....
probably going back in a few weeks once I get the car on the street to do some further tuning and crack 4-digits.
Damn those are some good numbers!
Glad to hear that you got the MS working good.
Did you log any of your Intake Air Temps? Just curious.
Do you think when using e85 that a squirt of meth injection would help keeping the Intake Charge any cooler?
