They must punch the mounting holes out at the shooting range. And not be a very good shot. Damn.
You should flow it on a head like it is for the heck of it. For those OTTB guys!Yes I did that’s kinda why I put some time into this today in the shop. Thanks
I did. Was waiting......Guess you didn’t see my post earlier showing what to expect. Luckily the amount the gaskets needed to be moved to line up as well as bolt hole s elongated was equal on mine.
The two Mr Gasket Ultra-Seal (5840) gaskets lined up on the flange using the bolt holes originally looked about the same as in your pictures.You wouldn’t believe how close I came to ordering one of these today. Can you post up the picture of the mods you did to yours again.
I use Mr Gasket Ultra-Seal and/or FelPro 1213 and never an issue on my TF’s (used on Action Plus on other heads, and MP SP, AG etc)I did. Was waiting......
Please excuse the stupid question, but does that intake gasket match the cylinder head well?
Yes.............the Edelbrock I fondly remember.
The only problem with that is if the heads are port matched to the gaskets and you slot the bolt holes in the gasket so it matches the intake you still have a misalignment. If the heads are gasket matched the intake will have to be port matched too.Guess you didn’t see my post earlier showing what to expect. Luckily the amount the gaskets needed to be moved to line up as well as bolt hole s elongated was equal on mine.
Slot the holes in the gaskets? No. I guess I may have explained things in a confusing manner. Rereading my post yeah it is. There’s no cutting or moving the gasket obviously. Properly stated, the actual intakes bolt holes are elongated to be able to move it, in my case forward so it lines up with the gasket which lines up with the head ports. I’ve had a few intakes (gasket/port matched) on my TF heads and haven’t had any mismatch: roof, floor or sides. This is the only intake that needed the holes elongated in order to match up. I had a new Victor 340 I bought and ported late 2021 and it was fine, other than dinky ports. This newest casting is something entirely different.The only problem with that is if the heads are port matched to the gaskets and you slot the bolt holes in the gasket so it matches the intake you still have a misalignment. If the heads are gasket matched the intake will have to be port matched too.
Makes me want to check my Trick Flow I have tucked away.
******! You had me going, I was like “what now?!?”That TF intake is GARBAGE.
I take scrap but right now scrap prices are low so we’ll have to work something out on that.
Surely I jest. That manifold is a unicorn. Wish I had one to play with.
So what is the proper way to fix that misalignment?
If we had an LOL button…….They must punch the mounting holes out at the shooting range. And not be a very good shot. Damn.
if its new return it thats ridiculousSo what is the proper way to fix that misalignment?
