No spark
A coil can measure ok with an ohm meter....but still be faulty. Substitution is the way you check for a failed coil or ECU.
I tested coil with ohm meter and both primary and secondary coils are good.
Took ballast resistor out and checked it and it shoes 1.0 ohms of resistance
READ what I am telling you. Either the ECU is not grounded, or a wiring problem like a bad connection, or the ECU is toast
The coil has the same voltage on both sides of the primary. This means it is not drawing current. The ballast has the same voltage on both sides. This is all a series circuit, as I told you above. As the current comes (from ground, electron flow, the neg point) the current (if it is flowing) causes voltage drop along the way. There is none (voltage drop) so there is no current flowing.
The ECU should ground the coil negative terminal (so it would be 0-2 volts) at key on engine off. Either the ECU is bad or it isn't wired properly.
This is how I have it wired. I apologize for the crewed drawing.
The only thing I see different is i have the ignition and wire to ecu both attached to the ballast resistor..
I cannot tell by your drawing if the ECU connections are correct, but they seem to be. I don't see the IGN2 IE ignition bypass from the ignition switch. The "run" line from the key GOES DEAD during cranking. The IGN2 comes alive just like the start contact at the key, and feeds direct to the coi + side of the ballast
READ what I told you above in the previous post(s).
OP is not using a Chrysler ignition switch. It is just a temporary start switch.
I've been putting together a troubleshooting guide specifically for this.
How Chrysler electronic ignitions work, and what to check if they don'
I see you have power at the coil positive terminal, that's a start. Can you run through the remaining voltage checks and let me know what you find?
Stumbled upon your guide. Very understandable and easy to follow. Saved me from buying a bunch of random parts. Helped be resolve my issue of intermittent no spark once the car got warm. Turned out to be the module. Thank you!
