myduster360
60 degreeI'd like to hear what that sounds like without pipes if you were ever inclined to do so. Also do you know what the cylinder bank angle is?
Open cat on the right, open dump on the left.
As much as I like that engine, it sounded like a jap rice burner w/ a fart can ! lolcast exhaust is begging for a turbo..or 2!
Agree, that`s what would stop me from it , or a late hemi -------I`d want the 8 speed to go w/ it, I had a 4 speed/440 RT once, and don`t give a dam about shifting one after that , was a pain in the *** in the city !I'm kinda interested in this swap. I would want a turbo on it. I think the power to weight ratio would be pretty good but the wiring/computer stuff seems like it would be a nightmare.
Would be , if a guy can get it sorted out, I`d still prefer the auto tho.I'm a truck driver so shifting doesn't bother me...too much. My 05 Cummins has a 6spd and it's a pain in LA traffic. My Valiant is 4spd, so it's staying manual. I have a complete 5.7 Hemi with a 5spd auto sitting in storage. The wiring for that is not too bad because of the company's that do it. But that 3.6 has a ton of wiring with no aftermarket support. I think a 3.6 turbo 5spd setup would be great for my Valiant
The 3.6 makes around 290 hp in a wrangler. Over 300 in a Charger Challenger. I would expect the valiant to drive like a 340 car and be able to get over 30 mpg.
Not to mention Maserati uses a turbo charged version in the Ghibli. It is 3.0 with heads designed by Ferrari and twin turbos making over 410 hpABSOLUTELY! Same/better crank hp AND 1/2 the weight.
Even better, its not uncommon for the Supercharged and turbo'd variants to be making around 400hp at the Wheels.
Oh I know there are critical differences. I was really just pointing out plenty of performance potential. I worked as a mechanic at a Chrysler Jeep Fiat Maserati dealer. Have spent lots of time getting to know the 3.6.I saw that but its more different than similar. The only thing it has that's even remotely in common with the Pentastar is the block and maybe the water pump. The Maserati uses completely different heads, intake, cams ect. Its heads have "old school" individual exhaust ports and cast iron exhaust manifolds.
im planning a couple ecoboost turbos once I get it up and driving and the 300hp gets old
The 3.6l uses the same pcm as the 2012 and newer Hemi. The 3.6l v6 Jeep also uses the same 5speed NAG1 5speed auto that is a common swap. Just swap the bellhousing.
Hardly no aftermarket suppport.
The OP already has a Hotwire harness to use as well as a Quicktime bellhousing for the TKO.
Diablosport and Hptuners both offer tuning software.
Edelbrock and 3 other vendors have bolt on superchargers and 3-4 others offer Turbo kits.
I did not know Hotwire builds a harness for it. I recently saw QuickTime has a bell housing. I've heard about the turbo/super kits for new challengers (neighbor was going to buy one but never did). I met a guy with a nice 300 that said he was buying a twin turbo kit that was good for 600hp. That would be fun in my little Valiant. This is sounding a little easier all the time. Just have to look at $$. I think it would be the perfect drivetrain for the purpose of my car.
60 degree
That bellhousing is pricey!!!
Quick Time Bellhousing RM-4070: Steel Bellhousing Chrysler Penstart V6 3.6L | JEGS
Costly and heavy too. That's why I went a different route with a left over aluminum 3.6L NAG1 bell from a Wrangler Hemi swap. Jeep swap houses have piles of them and it was $70 shipped. I then designed an adapter plate and redrilled my flywheel. I've got ~$350 in it.
View attachment 1715187009View attachment 1715187004
That's great and I'm happy for you. Unfortunately some of us don't have access to the tools you do, so we're stuck paying for it. Any idea on how wide this 3.6 is? I have a '64 Valiant and I'm really considering this swap down the road. I've read the engine compartment is around 2 inches narrower then the '67 up body. Where did you get your engine from?
Any idea on how wide this 3.6 is? I have a '64 Valiant and I'm really considering this swap down the road. I've read the engine compartment is around 2inches narrower then the '67 up body.
doubtful, the OP hasnt been online since late 2018Is there an update to the vehicle?
