The Mopar 292 is what i found to fit the best .
Different filters have different flow specs. The Wix 51515 racing filter is a higher flow than a standard Wix... There are specs available for most name brand filters.You wonder at what point does all that media get in the way? At what point would you rather a little bit of dirty oil getting through as opposed to no oil?..
Food for thought...
You go crazy if you ran a dry sump system!!!!I like remote filter adapters. Always have, but I won't run them. WITHOUT FAIL they always start leaking somewhere at some point.
If you check the pressure drop across the smaller filter after a thousand miles (maybe sooner) you’d do what you can to fit the biggest filter you can. Small filters are more restrictive.
After some research about pressure drop etc it seems this makes perfect sense. I've got plenty of room to run a pretty big *** filter after going to an as least restrictive as I can fab remote filter mount system. Going from the short version to a filter almost double in height:I run the 2 quart size FL299 on the 351M in my truck and on my slant six in Vixen.
It's just something I picked up from working on big trucks. The old guy I worked for ran an extra large capacity oil filter on all his personal vehicles.After some research about pressure drop etc it seems this makes perfect sense. I've got plenty of room to run a pretty big *** filter after going to an as least restrictive as I can fab remote filter mount system. Going from the short version to a filter almost double in height:
However old you are is how long you ain't figured it out. So there's that.If he hasn't figured it out in 2 years, then I'd say that it's a lost cause.
I had it figured out from the very beginning, it's a easy fix,like someone said use a remote oil filter. A 90* degree oil filter adapter could be made to work as well by reworking the floor pan. Sometimes one has to study the situation.However old you are is how long you ain't figured it out. So there's that.
You got a car yet?..I had it figured out from the very beginning, it's a easy fix,like someone said use a remote oil filter. A 90* degree oil filter adapter could be made to work as well by reworking the floor pan. Sometimes one has to study the situation.
I had to put it off because of my renal artery surgery and now that I'm over that I have 2 great prospects to check outYou got a car yet?..
