wrlandscape
Member
Is the pickup tube different from a 318 to 360
no, only difference is when you're changing pan stylesIs the pickup tube different from a 318 to 360
I dont know if i had an oil pan spacer. Ill need to check on it.
No the orginal pickup tube was for the van which it wouldnt work for the car oil pan. I bought a new oil tube for a 318. My engine is a 360Where is the original pick up tube for the 318?
The pans are different so yeah. The 360 pickups 8've seen will run too far up into the front of the sump and starve the pump on accel.Is the pickup tube different from a 318 to 360
So there never was an original motor (318) in the car when you got it?Where is the original pick up tube for the 318?
No slant 6So there never was an original motor (318) in the car when you got it?
