Dusterdan340
Member
I am rebuilding a 1969 440 that was put into this 1968 Dart. The oil pan that was in the car shows a lot of damage from hitting on the K frame. I am not sure this is the original 383 K frame as the drivers side motor mount has been relocated. I am trying to find a new oil pan and pickup that will give me the proper clearances without the heat n beat process. I could go either stock capacity or maybe a deeper pan as conditions here warrant some ground clearance issues. The charts are no help at all for non production mods but I am sure someone has solved this problem. All input is welcome, thanks for your help.
