72Dart6pack
Harder Better Faster Stronger.
I take a sip of whiskey. I take a sip of pepsi. It mixes in my belly. Same results. I still get drunk. Lol
In the end, nobody changes their ways. I have no problem with multiple ways of getting the same job done.
Where did I disagree?
LOL.... read post 68. you hit the disagree button. I thought it was funny, because I listed two facts. 1). I have a Duster on VR-1 and 2). that I liked it (so far). So I asked if you disagreed with the fact that I have a Duster on VR-1 or the fact that I liked it?
Just jok'n/pok'n....
That's just funny .....Damn, why that **** is on the right side of the screen I'll never know. I had to hit that thing by accident. Had you not pointed it out I would have never know I hit it.
Wonder how many times I've hit something over there and not known it. I very rarely hit the disagree button. If I don't like something enough to hit that button I type it out. So I fixed it for you.
BTW, how did you know I hit the disagree button? I didn't even know I did it. Damn **** technical crap.
Oh, you can move your curser over them and see who agreed/disagreed. It will list them all for ya. Also, I get this red "alert" telling me when somebody agrees, likes, dislikes, or quotes anything of mine. You get the same I'm sure.
lol......... I thinks we all be truckers.... we love sitt'n around arguing....
picture ones show hole in seal....
picture two shows zddp being added to 5 qt jug of oil
picture 3 shows cap back on 5 qt jug of oil after being shaken ....
Z written on cap to let me know that the zddp has been added...cause same oil brand is used for pick ups...and other vehicles not needing zddp...
whole time took probably 5 minutes since I left the small 4 oz container drain while I was doing other things...multitasking ....
The issue with the above post is the tests they used. Not likely did either have a seat pressure of more than 80 pounds.
Also, the lobes tested are very slow lobes.
They also don't have a rocker arm.
This all makes a difference.
Has anyone done a more appropriate test?
Meanwhile I think I'll keep on running at least 1000 ppm (0.10%). The extra few bucks isn't a big deal, and with enough support on this forum I can handle the mixing problem ;)
this is true to a point. I called Valvoline company itself. They said if a car already has 60,000+ miles on it, the extra zinc isn't necessary. But new cams/lifters, it's very critical, especially the first few thousand miles while things continue to break in.I'm betting thousands of flat tappet cams have had long healthy lives
running regular 10w30 Dino oil with 800 ppm zinc or whatever.
I know why it was reduced... (and isn't it the phosphorus, not the zinc?).
What I'm asking is if anyone has actually run test engines with Mopar-sized flat tappets and lobe designs, and more aggressive springs (say 130 seat, 350 nose), with varying levels of zinc.
There's a lot of anecdotes along the lines of "I never lost a cam until I used VR-1/didn't add the zinc/bought lifters from Comp", etc. etc.
Gasoline has additives that are added this way into the huge underground tanks. They don't carry around 87, 89, 91, and 93 in the trucks. Oils also have additives from the production that have to get mixed in, so why not an additive from the end user. Personally, I didn't do it, I used Valvoline VR1 in my '80 Aspen, but nothing wrong with adding it in yourself.When I think about a tiny container of ZDDP dumped into a valve cover hole and whatever tiny bit of it making it down to the 6, 7, or 8qt pan. Then starting the engine, letting it run long enough for the oil pump to circulate and mix the oil enough to evenly mix in that ZDDP additive and of course carry the rest of it down to the pan.....
Does it sound ridiculous to you yet?
Buy the oil you need. Pour it in, start it, run it.
Mobil1 15W50 has over 1200ppm ZDDP, and it's available off the shelf at O'Reilly's.
I don't like additives because 1) you forget, and 2) when you top off the oil you don't get any.
Use Joe Gibbs break in oil then use valvoline Vr-1.
I'd like to use that in my '68 383 as I have had good exp with all mobil 1 ...have you ever thought it was a little heavy in your experience using it?.
