Bulldozer
free ice cream sandwiches
you need to pull the pressure out of your crankcase with the correct PCV valve from the valve cover to the carb.
exactlyOK, let me ask this. Is that cap on the back side open on the bottom with holes around it? If so that's your problem you aren't pulling air through the engine, just from the cap.
Nice covers for 50 bucks.
those breather caps are garbage. my system is completely closed. valve cover - pcv - carb. i have no breather what so ever and this set up works flawlessly . some use a breather on the opposite side of the engine of the pcv. if your carb is connected to a pcv breather with holes in it , your are sucking air and not crankcase pressure. there is a valve in the PCV that vacuum from the carb pulls open to vent. pcv= pressure control valve . your breather needs to be tossed in the garbage and the correct pcv installed.
ok well whatever it stands for is great, but you still need a new oneid hate to burst your bubble but pcv stands for positive crankcase ventilation pressure control valve is in the trans or other spots that are controled by pressure i work at a transmission shop
I believe that one of the Covers should have a baffle in it to keep oil from getting sucked up by the PCV Valve. The whole ventilation system is just a bit more complicated than we are giving it credit for. Most peoples setup is working great but I would read up on it and make sure you have it exactly right or you may have some minor issues. Such as, Oil consumption or seal blow outs.
Sounds good. I guess there's 2 schools of thought on the extra breathers but The PCV is a definite must.like i said earlier the only place i seen oil coming from was the dipstick tube neither tho im going into town tomorrow to get stuff for it
It sounds like he has his breather connected to his carb??? Isnt that where the PCV(after you buy a new one) gets hooked to?? Does the breather have to be hooked to anything??
