anyone interested in a filter for the norms Tri Power air cleaner if i make a few extra?
Maybe depending on cost.
Simple green and a crock pot, never heard of that but it looks like it worked good.
Why did you not just use regular carburetor soak?
anyone know of a 1.5" oval filter? this one just barely touches the hood, still might use it since it has locked motor mounts.
had to dump the log could not get it to stop weeping no-mater what i tried! took it out for a longer drive. when the secondary's open its like being shot out of a cannon!! very wicked!! only problem now is coming to a stop the idle dips down to 500/400 rpm or so it has not died. idles fine in park at 950 drive 850, timing is at 20 initial, float leval is just at bottom of sight hole.
that fuel log is going to heat soak bad off the valve covers. Best move it up and away and insulate it.
coming to a stop the idle dips down to 500/400 rpm or so .
Basic 360 ..home ported j heads, 11.25 cr. 200 psi cranking pressure. Solid comp 244/252 @.050, 520/540 lift cam. Comp roller rockers. 727 4,400 flash 9.5" dynamic converter, 3:55 gear tall nitto drag radials 275/60/15
Good morning. Interested in buying a few Tri Power air filters. Thank youanyone interested in a filter for the norms Tri Power air cleaner if i make a few extra?
Did these ever come to be?Good morning. Interested in buying a few Tri Power air filters. Thank you
2014 thread. Keep your fingers crossed!Did these ever come to be?
I know, toes too!2014 thread. Keep your fingers crossed!
Good ideaBetter to have started a conversation with the person instead.
