Sure do Rumblefish! In the website Gallery you can see a brand new "Hot Heads" hemi timing cover shot in High Gloss Clear (along with work progress pics in the Before/After subfolder) and an old loom in the same HGC. There is also a steel distributor hold down in the same clear to compare with the results on aluminum.
The customer was a bit disappointed with the overall color of the timing cover ... it came out too dark for his taste so my "zero return rate" record may have to be modified soon. What I recommend for those wanting to stick with a factory look is the color called "Blasted Aluminum." You can see it on the 340 6 pak and Edelbrock 318/360 manifolds in the Gallery (there's also before/after pics of the 6 pak so you can see how it lightened the color). The Blasted Aluminum can also be cleared, keeping polishing to a minimum and regular cleaning fast and easy.
LOL @ slaying you all ... I'm just a powder coater.
