BlueDream
Aspiring Mopar enthusiast
I came across a 340 locally that I can pick up for a fair price. For under $600 I'd get freshly machined '72 340 block with new cam bearings and freeze plugs, with the crank, rods, and new pistons. I also have a set of 915 J heads that I'd rebuild and put on the 340 if I got it. My car currently has a mild 318 in it with a COMP High Energy cam, Edelbrock Performer intake, Edelbrock 1405 carb, Hooker Headers, and a dual 3" exhaust (yes I know it's too big), a230 trans, 8 1/4 rear with 3.21's. My plan was to buy the 340 and build the long block with the parts I buy and the heads I have then I'd take what I could from the 318 like the oil pan, carb and intake, timing cover and front accessories, COMP 901-16 springs, true roller timing chain, rockers, and the valve covers. Is this a decent plan? Is it worth the trouble? And with the information I've given what would be a good cam to go with? I've been looking at the Thumpr line of cams. I want something that goes lumpity lump but still performs good. I'd like to know what you guys think. Thanks!
