You are getting a lot of conflicting information. Some good, some bad. Rusty and moper are both giving you good info. Just different ways to get there.
I am looking at a couple of your posts and the one thing I see is that you want to keep the costs down. If it was me, I would spend a few dollars and get a set of hyper pistons to get me in the 9.0 to 1 range, they are relatively cheap and then slide a Comp 268XE (or similar) cam into it. Then put your J heads and a vac secondary 750 Holley on it with a decent ignition. All that keeps the cost down and will put a smile on your face.
Jack
Jack
