This Bad Demon
I did a search but couldn't find anything. Anyone ever rebuild an outside door handle on a 1972 Demon or one similar to the style handle?
Just guessing, push button far as it will go and latch doesn't pop, or maybe it did but button wouldn't
Should be a tiny little hole in the latch side of the door, just above the latch. That's where a allen wrench goes in and loosens/re-tightens to adjust length of the actuator rod going down to the latch mechanism.
used latch? a lot of those latches are year specific, also did you clean & service said latch before installing? that thing should snap when being operated.
How does your latch work from the inside?
This could be as simple as the lock mechanism portion of this latch is stuck causing the outside door handle not to work.(how they are designed)
clean/ lubrication is your friend on these things ,Lawrence
Heard it was basically the same door handle as a mid 70's to late 80's pickup door handle
