So what is the advantage of centering overlap with TDC?
How bout with turbo engines?Power. It matters more if you have a functioning header. That’s why wide LSA’s don’t matter with manifolds. You don’t have the header helping with chamber filling.
Engines with manifolds and junk hearts are numb to LSA changes which means they are far less sensitive to cam timing than if you have a tuned header.
When you have positive pressure on the back side of the intake valve you are far less reliant on inertial wave or reflective wave tuning or scavenging to fill the cylinder. The small changes that really seem to effect an NA engine won’t seem to do much in a boosted combo.How bout with turbo engines?
410, 4 inch stroke, 6.123 rod length, 13-1 compression, peak torque 4800-5000 range, weight 3250 with me in it, 5600 converter and 1 7/8 headers. solid rollerPost your view, stroke, rod length, compression ratio and at what RPM you want peak torque and peak power and I’ll run some numbers.
Also car weight and converter stall speed. And header size.
Race gasI’m assuming race gas and not E85 or methanol. Am I correct (I forgot to ask)?
Race gas
272/288
110/107
Lobes I found that I like (what I like lol they may not suit your more sensible taste) are from Bullet:
Lobe # .020/.050/.200 LL 1.5/1.6
R302/450 302/272/196 .450 .675/.720
R316/460B 316/288/212 .460 .690/736
Or Howards:
R271/4544 299/271/194 .4544 .682/727
R288/4544 316/288/211 .4544 .682/727
I didn't look at Comp's stuff but I'm sure there are plenty of good lobes in there.
BTW, those numbers are for peak torque at 5K and Shift at 7k with a 10.5:1 effective compression ratio.
Edit: I had the ICL at 108 but it needs to be at 107.
Edit: I put my glasses on. it should have an ICL of 106 so 110 plus 4 degrees. I got it right this time.
Thank you very much for the information.272/288
110/107
Or Howards:
Those numbers only put peak torque at 5k rpm? 272/288 @050 on 410 inches seems like it would make peak TQ higher than that. At least in my head.
Interesting cam math but how does it determine cam specs with out any info on the cylinder heads?
Thanks that’s very cool and if you’re verifying what it’s predicting on your dyno then the math is good. I’d like to mess around with that program. Is it something you designed or did you buy it? If so who wrote the program?I ran the numbers again to make sure I didn’t end up with a green weenie but that’s the math.
So far, this math hasn’t lied to me. The math I’m using starts with finding intake duration. It’s based on peak torque rpm, stroke, compression ratio and bore size. And it’s weighted more to stroke and peak torque rpm.
Then it takes the intake duration and rpm for peak power and rod to stroke ratio to determine LSA.
Then it takes the LSA and uses whatever effective compression ratio you choose to determine ICL.
The last calculation is exhaust duration. It uses intake duration and a combination of piston speed and crank pin speed to calculate it.
One of the limits I’ve found is what I consider low rpm, low compression stuff. Say 9:1 and peak torque at 3200 and peak power at 5200.
It will almost always end up with a low 100’s or as low as a 98 degree LSA. If you then get the ICL, it will likely be 6-8 degrees advanced.
On the exhaust lobe, I can’t make the numbers make sense with exhaust manifolds. I get some pretty wild numbers that you would probably never would think of.
I suppose if you were doing a FAST build or something the numbers might make sense, but PRH or someone who is actually building or running a class like that can say if they have cams with very very tight LSA’s in their stuff.
Of course, that’s getting to the point that valve notches would be so deep that you just can’t fit all that lift around TDC and have a piston worth a crap.
My kid is coming home from college for Christmas and I’m going to have him look at the math and see if we can change the math a bit to be able to do stuff like that.
And I need to point out this math makes the assumption you are optimizing the engine for the rpm that’s been calculated. And really everything else.
Understood but..the air velocity is number one and the cams job is to control the velocity of the air through the port. The ability of a specific engine combination to use what the port is capable of is probably why some engines make more power than others with the same head. Using the port length and CC's you can calculate the average size of the port. Then using the bore and piston speed you can calculate the air velocity at each degree then in turn calculate the average port velocity that the engine is creating or demanding through a given port. If that number is too low or too high then power will be less than optimum.
I would like to see the math but i also have a copy of that book.
I messaged him on speed talk to see if I can come up with a copy and a cd.
You wouldn’t put fully ported B1 heads on a 408 inch big block with 9:1 compression and a peak power rpm of 6k would you? I know I wouldn’t do that.
Nor would I build a 632 big block with 915 castings (or any other garbage head like that) with 15:1 compression and peak power at 8500.
No i wouldn't and the reason is the air velocity would be to low for the 408 and too high for the 632. I liken it to sucking on a straw where my mouth is the piston, the straw is the port and my finger covering the end of the straw is the valve. How far i move my finger from the straw, how fast i move it and how long i hold it away affects velocity. I will dig out my book and take a look, i guess i missed that section somehow.
