ronw
Can anyone tell me anything about this distributor? Started engine with it and adjusted timing @ idle with a 508 cam about 1,000 rpm. Check timing @ 2,000 rpm, still the same, no advance. Should there be an advance? Ron
Dist produces a good spark, Checked air gap, Set @ 008. and have timing set @ 12Deg.You have that "sharp" reluctor in it also?
I am thinking it is frozen or welded. I am looking for one for my 440 they just have great characteristics.
I took the dist. out and the advance is free. do you still have the springs I need? thanks RonIt's just going to full advance when it's running, needs stiffer springs I have 2 of them at the moment I had 5 last year, it's a great distributor. With the cap off can you turn the rotor a little if so it's not frozen. I set the balancer at 5* BTC them line up the pickup with the reluctor point and lock it down, that is your starting point now check your max advance and see what you have.
Do you mean the weights are flopping around? or the mechanisim is free to move?I took the dist. out and the advance is free. do you still have the springs I need? thanks Ron
The mechanism is moves freely and has springs and from what I have read it needs stronger springs so it is not full advance at idle. What those springs are I do not know. Can you help and do you have the springs I need? Thanks RonDo you mean the weights are flopping around? or the mechanisim is free to move?
What are you trying to do with different springs?
