ValiantKindOfGuy Well-Known Member Joined Aug 14, 2019 Messages 392 Reaction score 112 Location Plympton Mass Aug 30, 2020 #1 Anybody test pac 1903 from 1.8” down to 1.2”. Need pressure measurements haven’t got the heads yet but I want to order springs if they won’t work. Cam grinder recommended 140 on the seat and 340-360 open.
j par Well-hung Member Joined Jul 2, 2014 Messages 33,169 Reaction score 20,815 Location Portland Oregon Aug 30, 2020 #2 @70aarcuda
PRH Well-Known Member Joined Dec 14, 2018 Messages 4,944 Reaction score 7,722 Location So. Burlington, Vt Aug 30, 2020 #3 On my tester they check very close to the published specs. Which are: [email protected] [email protected]
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Aug 30, 2020 #4 installed Height/Pressure: 1.800"--145# Pressure @ .550" lift: 358# Pressure @ .600" lift: 375# Pressure @ .650" lift: 400# Pressure @ .700" lift : 425# Coil Bind: @ .750" lift Outer Spring ID/OD: 1.075" /1.459" Inner Spring ID/OD: 1.078" / .794" Type of Spring: Dual Spring Rate 391 Best to ask PHR.....
