daredevil
Whats the shelf life of auto paint?
uncatalyzed paint as long as it isn't exposed to air has an indefinite shelf life.
yep- if it freezes it's done.I was told also not to leave your paint in an unheated garage in winter. Bring it in the house.
Um I have paint on my shelf that has 15yrd old dates and it still lays out just fine..... Lots of the paint at work (urethane, lacquer, singe and base) has been around for a heck of a long time and it still works just fine....I've watched this thread for a few days with interest........
No paint technology on the planet has an infinite shelf life. Plain and simple.
The old air dry lacquers would seed out in a matter of 2 months if left in an unreduced state. Weeks if the chit was reduced. Man I hated this technology!!!
The old air dry enamels would go to gum in 4 to 5 months unreduced, Much quicker if reduced and uncatalyzed. Catalyzed = hours.
The acrylics were a little better for shelf life that air dry enamels, but not much.
2K Urethanes were better for shelf life yet if unreduced and uncalatlyzed = 6 months if the temp and humidity was just right Reduced 2 months max and catalyzed = minutes.
You have a lot of additives such binders, silicas, flow agents, rheology control agents, UV and light stabilizer packages, not to mention the old lead based pigments, etc. etc. would break down or gel. The paint may not look bad in the can but the coating's properties would be lacking or completely shot .
Catalysts break down almost as soon as they are canned so shelf life is short.
I hope this info has answered a lot of questions.
sscuda
What is in the old enamel paint that would freeze? It was all oil base. We have used enamel paint that set in storage for 20+ years and never had anything that didn't work and look correctly. That would have been 2002 when we bought the contents of the store. It had been closed for several years before that so it would have froze. It did take a shaker to get it mixed up evenly before you tried to use it.
It was, but these days everything is changing to water base paints and it's going to be a new animal to deal with. All new problems to figure out and issue upon issue that will arise in the new mixing chemicals. All the reducers and hardeners in stock on the shelf will be worthless. It will be a gigantic PITA.
Have they gone to water born paints there? Right now we still have the good stuff.
A little bit more of "Big Brother" looking out for us??Not yet, but rumor has it it is coming, and soon.
