sunroof360
I will check on it next day or so and try to add pics.Is the shifter any good If it is restorable how much and is linkage there
OK ThanksI will check on it next day or so and try to add pics.
The grill has flaws, it has 2 holes on the lower flat part. And with shipping being so costly, I do not think it would be a good deal. If someone wants a picture, let me know. ThanksCondition of the grill? Any cracks?
Just to confirm, are you needing the upper roof rail “U” shaped channel that holds the weatherstripping? Once I understand exactly what all parts you want, I send you a Pm with the parts price. The parts are long and shipping will be expensive to cali. I will need your zip code. I will be gone this weekend, so it would be Monday before I can start boxing and getting you a shipping quote. I will remove and provide you complete pics, next week. Do you need the drip rail stainless steel trim. ThanksWeather stripping on both side doors with bolts also ?
Shifter is very rusty, several of the plastic bushing are broken. I will get it removed beginning of next week and can provide more and better pics. Sorry about the delays. I would consider it on the rough side on condition.Is the shifter any good If it is restorable how much and is linkage there
Thanks. Bolts may be ok. I will remove Monday and take complete photos. Pm coming with price on parts, will figure shipping next week.Oh bolts rusty well i am sure they sell replacement oem bolts and zip code 95422
No problem I have lots of time I can see you are a busy Man by All the questions about parts if possible I would like the tower The shifter is mounted on also. I know shipping might cost a bit but being as far as I am that's ok I appreciate your taking the time Feather DusterShifter is very rusty, several of the plastic bushing are broken. I will get it removed beginning of next week and can provide more and better pics. Sorry about the delays. I would consider it on the rough side on condition.
Thanks for your patience, I will hold the parts for you, I will be off line until mid day Sunday. I will get parts removed and post some pics, for you to view. I will work on pricing. Talk to you early next WeekNo problem I have lots of time I can see you are a busy Man by All the questions about parts if possible I would like the tower The shifter is mounted on also. I know shipping might cost a bit but being as far as I am that's ok I appreciate your taking the time Feather Duster
ing forward to hearing from You have good time and weekThanks for your patience, I will hold the parts for you, I will be off line until mid day Sunday. I will get parts removed and post some pics, for you to view. I will work on pricing. Talk to you early next Week
I would be interested in the spindles and caliper adapters (splash shields, too if they are decent) PM me a price shipped to 49417 for those parts. also, Ubolt/shock plates if it is an 8.25 rear.Yes it has disk brakes, but all parts are very very rusty. I feel like you would be disappointed, in the parts. This is a junkyard car, very very rusty. Thanks.
How much are you asking for the hood scoopI can
Dr
someone started started stripping drivers side, fiberglass is showing.
Floor Shifter and shifter mount/ tower parts. This shifter will need the spring replaced, and the bushings are missing/damaged. Come with the linkage to the trans. Parts are rusty, but solid. The tower will need to be removed /drilled from the trans tunnel brace but this way you can see where it lands on the brace. pm coming with price.Look
I think another member is going to buy all brake parts. All rear parts gone, or too rusty to fight to remove I will check on splash shields. ThanksI would be interested in the spindles and caliper adapters (splash shields, too if they are decent) PM me a price shipped to 49417 for those parts. also, Ubolt/shock plates if it is an 8.25 rear.
