1970Duster
- Joined
- May 30, 2010
- Messages
- 6,644
- Reaction score
- 215
Are the pedals from a 3 speed duster the same as a 4 speed duster? Asking because I dont know (wouldnt put it past Mopar to use different pedals)
I believe there is, the 4spd's have a much heavier spring. Someone else will chime in with more info Im sure
pedal setup should be same 3 or 4 speed !
Is it just the spring that is different?
Wow!!! Lots of info there! Thanks for the link.:cheers:There is a difference guys...take a look at this link
http://www.forabodiesonly.com/mopar/showthread.php?t=139846
As long as you're comparing same year A bodies, the pedal assemblies are the same. There's 63-66, 67-72 and 73-76.
Nice! Didn't think a spring would be needed to a Hyd. clutch, I'll go check Center force out.I know you didnt ask but if you use a center force cluth you don't need the spring anyway.
exactly x2
the link above shows difference in 67-72 compared to 73-76 is all !
same on both 3 & 4 speeds as yrs shown by StrokerScamp
hi fellas i dont mean to rehash this but are the clutch pedal assys the same for all dusters
73 and up? or to put it another way can i use a 74 slant six duster clutch pedal setup in a 73 340 duster application? (if not-what mods are needed to make it work properly?)
also is there a difference between a 73 floor shift colum an a 74?
thanx.
