I am talking about degeeing a cam, to get the best performance result.
The lobe centerline angle is ground into the cam profile, but the intake centerline can be set from the mechanic.
For example - my english isn´t perfect
When I am looking in the instruktion manual of my 2177 Edelbrock camshaft, I can see a 110° lobe centerline angle and a 106° intake centerline.
Timing at .050 Lift:
Open Intake 4° ATDC 28° ABDC
Close Exhaust 36° BBDC 12° BTDC
With the bad duration this cam is having low overlap. But when I change the intake centerline, I might get better times?
I hope you understand my question.
Best regards - Martin
