I'll be sending my model off for the prototype print in a day or two. I'm having to tweak things after taking out the existing instrument cluster and taking some final measurements. This isn't the final version yet, still got some tweaking to do. But it's getting close. I expect to have some trimming to do where the two large gauges will hit the bottom edge of the cluster opening, hopefully that will be all. Still figuring out the mounting method. Easiest right now seems to be to put some pockets for square nuts on this thing, and bolt through from the back using the existing holes. We'll see in the next couple of days what I decide on.
In this render you'll see a couple of shapes near the bottom, I'll use those to punch out a hole for the steering column once everything is finalized.
Once I send the file off I should have the piece in under two weeks. Total print time I believe will be around 38 hours.
