I guess the biggest thing is to change my mind set.............I know how a" port window" should look........But every time i see one, all i want to do is smooth up and round everything to make it follow up the ssr turn.
I need to let the "wall" air and the ssr air travel into the bowl not up the ssr. (Trying to get as much of the air, as possible to run up the ssr to the seat......is a bad thing......but i keep doing it)
Why! I say i need to change my mind set is that, my "mind set" says that Sharp Edges are a NO NO!!!! The more round, like a pipe, you can make a turn the better it will hold on or keep air attached to it.
Well if you put a finger on the ssr of a stockport(from the floor side).......well it's like a pipe that you have Stepped On! Not a smooth radius round section of a pipe........I need to except that this is ok.
