Ok, 2 questions. Was your damper at the 0 Mark? Are you sure you did not install the distributor 180 off?
If your timing was set to 12 TDC, the the reluctor should be about 12 degrees clockwise of the pickup nipple. Are you sure you are not timing it at 12 after TDC?
The relative position of the rotor cap to the reluctor does not change, I agree. The rotor cap position relative to the distributor cap does change. Mechanical advance rotates the shaft relative to the stationary pickup, which is attached to the stationary distributor and cap, thus firing the coil sooner.
Did you even read my comment, or do you just want to argue?
Before you call me "buddy" re-read my reply to your correct statement. I agreed with you!
The reluctor and the rotor are LOCKED TOGETHER on the same shaft. However, the rotor/reluctor's position relative to the pickup/distributor cap does change, else you would get no advance. The keyed shaft that fits the oil pump drive shaft always stays locked to the cam/oil pump drive. The shaft the reluctor/rotor is mounted to advances up to 15 degrees (30 timing degrees) relative to the oil pump drive, controlled by the counterweights and the springs.
.....................................However, at TDC, when timing is set to 0, the rotor should be 5-15 degrees AFTER the #1 wire location on the distributor. Therefor, as the mechanical advance kicks in, the it gets closer to center and then a few degrees positioned BEFORE the #1 wire location.............................................
...................Since the Distributor rotates once for every 2 engine rotations, that means the spark has to jump 1/2 that range of advance, e.g. 27.5 degrees....................................
......................If the starting position of the rotor is aligned too close to the #1 position on the cap. Thus, when you add 27 degrees, you are over 1/2 way to the next cylinder in rotation, and all kinds of weird things happen.................................
Mopar to ya, ever have that dizz apart?
WITHOUT KNOWING which hole the no1 wire is in those pictures show nothing. What you need to do is this:
Put the marks on what you believe the timing to be set at
Carefully scribe directly under the no1 plug tower, remove the cap, and put a small file mark to match on the top rim of the distributor. THEN take a picture of the dist. with the timing marks at whatever you believe the timing "is," 10BTC etc
Each reluctor represents 90* of crank rotation. This means, for example, in your first picture with the marks at TDC, AND DEPENDING UPON which tower the no1 wire is plugged into, either the timing is about 15 BTC or way WAY after TDC, probably as much as 50 degrees.
You can tell this by looking at the reluctor tips. Each tip represents 90* of crank rotation. This means if you "eyeball" 1/2 way between, that's 40-45* advance/ retard, depending on what "hole" you are "in."
In this case, we are talking about maybe 1/4-1/3 between.
WE NEED TO KNOW what hole no1 is in for certain.
You might want to use a piston stop to be sure the timing marks are correct, know how to do that?
You should be able to "set up" the engine with no1 ready to fire, the timing marks wherever you want the timing (10-15 BTC, etc) and just set the dist. in with the reluctor pointing to the middle of the pickup. Make sure the rotor points to where no1 is plugged in. With that setup, the engine should fire right up with no fuss at all.
How about mechanical advance, have you revved it up to see what you have for total advance?
When you said 180 degree rotation of the distributor would not run, does that mean you actually tried it?
