dICKj
Can l use my 1974 Duster power steering pitman arm on my swapped-in 1970 manual steering box?
From your comment I gather that I will have to change to idler and center link too?The sector shaft sizes are different, and if you look, they are probably different in the way the attach to the center link. '70 from the bottom up, and '74 from the top down. Pittman, idler, and center link changed to the later style in 1973. Moog K7075 should be the one you need.
Right, but the large PS arm from his '74 won't work with his manual gear, will it?Sector size is the same. The 72 back used a smaller sector shaft on PS only.
No, with the right Pittman arm you'll be good to go.From your comment I gather that I will have to change to idler and center link too?
