I've been searching and reading tips on here for home alignments for several weeks if not months. I know it would be faster to have a pro do it if I could even find the right one but I like doing whatever I can myself. I installed the Moog problem-solvers as directed for max positive caster and set the cams fully in in the rear and out in the front on both sides. I'm using 2 pairs of thin Teflon cooking sheets with grease between them as slide/turn plates. Using a digital angle gage on a steel plate across the center of the wheel, the driver's side was actually perfect at 1/2 degree negative camber with max positive caster. However the passenger side was at 0 degrees. The following are the steps I took. Good logic or I'm an idiot, I would like to know either way. Obviously, I have no idea what positive caster numbers I'm able to achieve but I'm just going for the max possible with factory upper arms and the offset bushings.
Step 1 - I adjusted the front cam on the pass. side in to achieve 1/2 degree negative camber. With the rear cam all the way in, I believe that wheel now has the max positive caster possible with 1/2 degree negative camber at my ride height?
Step 2 - I turned the steering full lock, both left and right, and took camber readings for inward and outward tilt for both wheels in both positions. I had about a 2 degree difference in the numbers from full right to full left.
Step 3 - I adjusted the driver's side rear cam out and front cam in slightly to maintain 1/2 degree camber while taking away some caster. I ended up repeating this step 2 more times until I achieved equal camber numbers full-lock both directions.
Step 4 - I haven't done this yet but I will string the car to check and adjust the toe. If the toe has to be adjusted, I assume that I should then recheck the right and left camber readings afterwards?
Step 5 - Drive it and see how it handles. I can't do this yet as I am currently waiting on a radiator and Illinois had enough winter weather this morning that the salt trucks were out coating the roads with the car-eating chemicals.
I would like to know if it seems that I am on the right track. Thanks to all.
