It needs to be wired in. Charge the battery on a charger before restarting with the alternator circuit wired up.Im not getting anything out of alternator so probably need a new one or voltage regulator?
Charging Battery with Alternator - Warning
We've discussed this here more than a few times. Usually about how easy it can be to cook the battery or overloading the charge wiring. Here's another reason. "Any attempt to charge a low battery by the alternator will result in stator windings burning out" ebay item # 222689173585 This is...
www.forabodiesonly.com
