harrisonm
Nice looking car. Is there anything better than a 69 F8 green Barracuda Fastback?Glad to hear of your recovery. '69 Barracuda would like to purchase a headlight relay kit
He's making them. He'll ask you some questions about where you want the relays mounted and you'll need to give him some exact lengths. I mean exact. As in, grab a spare wire or string and put it in the channels exactly how it's going to be laid. He'll make you a plug and play kit that will change your night driving experience.I would like a headlamp kit. Are making them now? Let me know the info please. Thanks.
Thanks.He's making them. He'll ask you some questions about where you want the relays mounted and you'll need to give him some exact lengths. I mean exact. As in, grab a spare wire or string and put it in the channels exactly how it's going to be laid. He'll make you a plug and play kit that will change your night driving experience.
I would like to get one of these for my Demon.Headlight relay kits that are essentially plug and play.
There is a substantial increase in voltage at the headlight, increasing light output performance. Light output degrades exponentially with voltage input reductions. These kits also take headlight amp loads off the fragile bulkhead connector, headlight switch and amp gauge. The only headlight load flowing through the bulkhead is a minimal current required to trigger relays.
The kit includes:
Bosch/Tyco relays (no 1$ chinese relays)
Ceramic headlamp sockets
Fuses/fuse holders
12ga wire from alt to relays
12 or 14 gauge power wire from relays to headlight wiring (no 16-18 gauge wire like factory, except 16ga to trigger relays)
All terminals for hook up to a std 1/4 alt stud and ground locations
Wiring would follow normal wiring harness paths and be covered with black shrink tube for most of the run lengths.
NO CUTTING OF YOUR CURRENT WIRING HARNESS REQUIRED!
Road lamp relay kit is not included in the standard 2 and 4 headlight kits. There is an additional charge for a road lamp relay kit.
The kits I've built have relays mounted on the yoke (front or rear), under the battery tray and inner fender uprights.
Picture of the light output difference from a 71 Cuda. Both pictures are on low beam setting, Left - before, Right - after installation.
Another benefit that most users see are an improvement in dash light and marker light/turn signal brightness.
Some other things to consider.
Unless you buy wire in bulk, you'll have about $40+ before tax in different colored wire packages from a local auto store.
All kits I build are tested prior to shipping.
Kits for a 2 headlight vehicles are $135 + shipping.
Most 4 headlight vehicles are $160 + shipping.
The assembled kits fit nicely in a USPS flat rate box, shipping in the US would be in the $10-15 range. International shipping is available. Kits have been shipped to Canada, Spain, Italy, Germany, Australia, New Zealand and a few other countries. Most all shipping is done via US Postal Service unless other service is requested.
Kits with all products and wire required to build one yourself are $85 for a 2 headlight and $100 for a 4 headlight + shipping.
If you would like some other iteration of a kit, parts only, please PM me.
All items are shipped from Indio, CA
Thanks to all my customers, I appreciate your patronage!
I would like to get one of these for my Demon. Message box is full.Headlight relay kits that are essentially plug and play.
The kit includes:
Fuses/fuse holders
You were right. It was my inbox full. I will send you a pm with info you need. Thank you. Chuck@VitaminDemon
Are you sure it's not your message box at 15 that is full? I got the "Box full" when trying to send you a PM. Mine has plenty of space. Could be a site snafu...
Let me know engine and if you have a wire around/ammeter bypass in place. Also if you want relays hidden below battery area or on the back of rad support/pass side.
I can take care of the rest.
Rob
