Yup Schumacher is out of them two.
Torque Straps
How do you stay in business when you have NOTHING to sell !!!!!
Torque Straps
How long ago did you buy your last one?
Reviving this old thread. I’m looking for alternatives to the saggy Anchor original style mounts. I have a 400 hp 340 and TTI headers with a manual transmission. Just tired of the saggy mounts and headers knocking the torsion bars. Despite many hard launches on drag radials the rubber mounts haven’t torn but they’re definitely sagging and very loose it’s annoying. Will the poly mounts address this issue?
Yep. If you have a 4-500 horse powerplant it isn't going to be a smooth and quiet Chrysler Imperial like experience anyway. Solid mounts might add some vibration but not a issue in a true hot rod.I have about the same setup in my duster. Manual steering box, TTI’s with stock Zbar, 73 up drag link / brakes. I have the poly locks in with no problems of hitting the Tbars launching the car. I’m running Falken 615’s, maybe not as sticky as a drag radial... I have a rod style torque strap that was in when I had my other K frame in with rubber mounts. I’ve not put on the current K frame I have in the car with the Poly Loc, but will be soon. I can’t speak to the failures, but clearly other guys have had them. If your mainly drag racing the car, put solids in. I bet @yellow rose would say screw it and run solids on the street also...
I tried solid mounts and didn't like them. Took them out and sold them to @yellow rose Just to much vibration. I went with Poly Loc's, no problems so far. My 69 Dart has a mild 360 with A/C, P/S, 727 .
give it a few years , they will deteriorate and come apart , i thought they were great as well until i read a thread here and checked my poly mounts they were shot and it was not oil leaking on them no oil leaks on my carI tried solid mounts and didn't like them. Took them out and sold them to @yellow rose Just to much vibration. I went with Poly Loc's, no problems so far. My 69 Dart has a mild 360 with A/C, P/S, 727 .
lucky i don't drive a million dollar race car thenAll cars leak oil, even million dollar race cars...
