Looks good, what's your size of wheels?
This thread is brilliant-nice work on the parts bin engineering and simplified fab. I'm also confident your 3/8" angle iron should suffice given the application. Angle iron is usually made from hot rolled carbon steel or something similar and most carbon steels have great fatigue life and yield/ultimate strength. The suggestion above to check for cracks using either dye pen or mag particle are solid processes and are used every day in aerospace for the same reasons. Any competent machine shop should be able to do them for a reasonable cost.
After you get past a shakedown phase and get it dialed in, it would be supremely cool if you could record/report those findings either in this thread or a new one. I couldn't find any specs for 60-0 braking tests for the stock Dusters of that vintage with a quick search, but I bet they're out there somewhere on the interwebs, and I'm betting it's somewhere around 140-160 ft...
Did you do this only on the front or did you swap out the rear drums as well?
I'm surprised they fit under stock wheels. I thought the brembos on my jaguar were large then I saw how big porsche calipers were.
What made you decide on the Porsche calipers? Great work. What size MC are you running?
Any "before" data? How much improvement?
Mopar muscle did a rear disk conversion on a '73 Dart Sport and checked the stopping distances between the rear drums and rear disks from 60-0. Their result was that from 60 mph factory disks up front and factory drums in the back the car took 133 feet, 6 inches to stop. After the rear disk conversion, the stoping distance improved to 122 feet 4 inches.
The online article is a total mess now, probably something with being converted over or moved to Hot Rod when MM was bought out. The final distance used to be a caption on the second to last picture, but I don't see the captions popping up anymore. The hardcopy article is easier to follow, but that's the way it goes.
Rear Disc Brakes - All Bound Up - Mopar Muscle Magazine
Now, there are other differences here no doubt, tire compound, road surfaces, driver input etc all make a big difference which makes comparing two different "at home" kind of tests hard to do. But the numbers you're getting are A LOT better than what Mopar Muscle got. And their stock numbers are pretty close to the factory published numbers I've seen. I'll have to look it up but somewhere I saw a drive test article from back in the '70's on a Demon that put the stopping distance around 125 ft if I remember correctly. I'll try to find it.
***Edit***
Here's a Road Test Report on a '71 340 Demon. Not the one I was looking for, as this is a drum/drum car. Neat stuff though. The stopping distances were absolutely abysmal, for anyone that says drum/drum is ok on the street today. The Road Test guys said they expected a 60-0 of 155 to 165 feet. What they actually got was a stopping distance of 169 ft, on a 3,250 lb car with E70's. That was their "best" distance, not an average of their results but a one off. Their Demon had 10" drums and a power booster. They did say their road surface wasn't ideal, but dang.
Vintage Road Test: 1971 Dodge Demon 340 – Road Test Magazine Takes A Real Devil For A Spin
Hi,The piston size in those calipers might be a little on the small size so keep an eye on your proportioning. I used Big Reds from a 911 Turbo when I did my Porsche swap.
