You shouldn’t need custom fuel rails, edde sells a fuel rail kit for their LA super victor efi manifold that will work for whatever manifold you decide on.
I’ve got a kegger intake in storage along with the factory fuel rails. I’m hoping to be able to use those to avoid buying new ones.You shouldn’t need custom fuel rails, edde sells a fuel rail kit for their LA super victor efi manifold that will work for whatever manifold you decide on.
The nice thing about the factory rails is that you’ll be able to use the injector retention clips at the top. If you need another set, let me know. You can have the ones I took off my engine.I’ve got a kegger intake in storage along with the factory fuel rails. I’m hoping to be able to use those to avoid buying new ones.
Sounds like you've been there!
Edelbrock Streemaster ? Great intake for torque, all done by 4500 rpmWow, both intakes are not to good for the build. The cam is way small for what I’d run the Offy, given the choice.
Holley did t make a “Street Master” but Edelbrock did.
Holley made the “Street Dominator.” Which I’m not really fond of.
A Complete garbage intake, use as a door stop, show to a class on a “What not to do!” Great for jokes at the camp fireside story time, camp fire fodder, best used as spare change when properly thrown the scrape pile.Edelbrock Streemaster ? Great intake for torque, all done by 4500 rpm
So let’s flip the table here for a second and ask “which intake is worse” instead of “which intake is better”…A Complete garbage intake, use as a door stop, show to a class on a “What not to do!” Great for jokes at the camp fireside story time, camp fire fodder, best used as spare change when properly thrown the scrape pile.
At best! Save for patch work on other aluminum items?
I think they are equal turds.So let’s flip the table here for a second and ask “which intake is worse” instead of “which intake is better”…
Street master or the original Torker?
Just Spin it on up there! YeeeHawwEqual turds- ummmm, yep! I don’t like ether intake.
A lot of people crap on the TorkerII 360. I give it this, way to much plenum. If you can deal with that, it’s not a bad intake. I just don’t see paying a lot for it. I’ve had one. Actually it is the first intake I ever purchased. Once I got enough pump shot in it, it was fine for me. With that intake, even though it’s says 2500-6500, it’s better at 3K plus. Ignore the lower end, build a beast with it. Damn the mileage, full throttle ahead!
I have the book.When they did research on plenum sizes to dampen reversion they found that the ideal size was 8 x 1 cylinder volume.
Its some where in the "scientific design of exhaust and intake systems. By Philip H Smith and John C Morrison.
