Post 11 second small block combos
68 dart 3250lbs 365" 10.3 compression ,edelbrock heads done by Modern Cylinder Head, .590 mopar cam, M1 intake , 950 hp carb, Hedman 1 7/8 headers full 3" exhaust with x pipe. 904 trans with 4800 stall PTC 8" converter. Have run 4.10 gear with 28X12.5 et streets and 4.88 with 30X10.5 radial slicks. Best et 11.07 @ 121
73 duster,no interior,lexan windows,tilt fiberglass front end,weight ? 360,.030 over,Kb-190 pistons,308 heads w 2.020 valves,mild clean up, Racer Brown 245 @50-.530 lift w 1.6 roller rockers,1-5/8 headers w 16" stingers. Holley strip Dom intake 750 dbl pumper w proform maine body. 727 trans w 4600 stall ,4.88 dana 60 narrowed,ladder bar w coil over shocks .Best so far 11.802-1/4-113.51,1.637-60'. Track in Fallon NV,4000'.Density when made pass 6800'. Still working on tuning hopping for more. Will post picture when i can figure out how.
72 Duster
3400 race weight
360
stock cast crank
stock rods with ARP bolts
$130 Sealed Power .050 down the hole 4 valve relief flat tops
596 heads moderately ported 1.88/1.6 valves peak flow 230/170 @28"
Hooker Super Comp 1.75 headers 17" extensions
252/252 @ .050 .528 lift solid 108 LSA cam
RPM Air Gap intake 750 double pumper
904 trans
8" ATI 5800 converter
8.75 rear with 4.56 spool
28.5 slick
90 octane pump gas
1.44 60 ft
7.01 at 94.97 1/8th mile
11.18 at 117.5 1/4 mile
1700 DA
Hoping I can get 10s out of this dumpster build motor.
UPDATE
1.42 60 ft
6.91 at 96.49 1/8 mile
11.00 at 119.1 1/4 mile
So close to the 10s yet so far.
[ame="https://www.youtube.com/watch?v=q5LMF2GMETs"]20150328161425 - YouTube[/ame]
Hi, gotta update this here.....
after changing to 1.6 Rockers (Mancini / HS bodies) this winter and putting on new calipers, i did some testing this last weekend at the first Drag event here. After some 11.7 passes (i did not expect that much difference) i got a new PB: 11.61 @ 115.1 mph, 1.67 60ft. I´m pretty happy!!!
So i think the engine want´s more cam. We´ll see what´s going on this year, if i can save enough money i´ll upgrade the cylinder heads and the cam next winter, maybe the intake, too.
And I will change from the 727 to 904, that´s for sure (already have a good core to rebuild). A custom converter will find it´s way in the car then, too.
I had a great weekend!
Michael
Hi,
i´m pretty excited, was at the drags this weekend, after some low 12 sec. passes i finally got an 11.98 @ 113.5 mph. 68 Valiant 2dr Sedan, full interior, 408 cui with Indy X-heads, Comp XR286HR cam, EDE Performer RPM, 750 Holley HP DP (AED). I recently did the trans and put in a 3500 stall converter (Turbo Action 17805st).
Now i have to repair the left front caliper, it´s sticking and i think i left some time there. Will try some 1.6 Rockers in near future. I´m positive that there´s more in it, best 60ft. time was 1.79, i think there´s also room for improvement.
Michael
p.s.: the pic is from last year....racing my swiss buddy Marc. He´s a nice guy with a cool 318 on juice, also in the eleventies.....
8/29/2015 73 Duster 3550lbs 414 with Mopar 528, Edelbrock OOB heads, Edelbrock STR 1-2 with 450dp Holley carbs, Heddman headers, 3500 stall reverse paten 727, 8 3/4 with 3.91, stock suspension with SS springs and snubber and 28" tall MT ET street radials.
1/8 mile [email protected]
[ame]http://youtu.be/lTrmRx6EUGo[/ame]
72 Duster
3400 race weight
360
stock cast crank
904 trans
28.5 slick
90 octane pump gas
1.44 60 ft
1700 DA
Wow, that gives me hope for my "dumpster" build, lmao.
360 block, 414 CI, pump gas 10:1
Ported Iron Ram heads, 1.65:1 roller rockers
251/257, .564/.564 110 LSA cam (Comp XE295HL)
Reverse pattern manual shift 904, 3500 turbo-action converter
Dana 60, 4.10 SS springs, MP drag Shocks in rear, Comp Eng 3 ways in front
MT Street ET Radials 275/60-15
Best ET 7.34 1/8 (about 11.50 1/4)
Best 60' 1.6
Only made 6 passes and had traction issues. Hopefully be low 7's or high 6's (low 11's) once I get it to hook up.
Been a long time. Update to above (same combo, just some adjustments):
[email protected]
1.537 60'
Doing some weight reduction & other tweaks to hopefully get it down some more.
My 69 dart 340 4 speed combo.
68 340 block. Bored 30over
Forged pistons range of 10.1 or 11.1cp
Steel crank.
Edelbrock performer rpm intake
Edelbrock 750 carb+1inch spacer.
Comp cam shaft mp 508 lift.
X heads springed ported and polished
Doug headers 1-5/8 long tube to 3in collectors. Built for racing.
Holly red electric fuel pump.
Too much to list.
Guy who built it said 430-450.
A-833 with differnt ratio.
8-3/4 391 posi.
Did 11.34-11.55 depending on weather and launch. No cage always a thrill.
Seen a couple at the local strip.
68 340 488 or 509 cam. Toker or m1 intake stock x heads forged pistons. 400-410hp One in a 72 dart did 12.35. But with 904 and no shift kit next year he came back with a 68 dart and a 4 speed added headers did 12.05 first pass and hit 11.8s by the end.
