moparmanjames
Member
72 Duster 2x3 chassis, 526 wedge, glide, 9inch, 4.10 gear, 32x14.5 tire, 3200lbs, 6.4 @108 ish in Las Vegas with poor air.
10.0 @ 135 through the traps.
sold my 70 dart but my combo at 3000#.030 over 360
stock cast 360 crank
ported Edelbrock heads. 2.08 valves open chamber 340 style head
Ported Victor 340 intake
JE flat top pistons
app 10.8-1 comp
1 7/8 headmen headers
H beam rods
600 lift roller cam
Harlan Sharp 1.5 rockers
750 and 900 alcohol carb. ran the same with both.
3200 pound Duster at the line
727 transmission 5600 stall conv.
8 3/4 rearend with 4.10 gear and caltracs
Its gone 6.54 several times
View attachment 1715243068Untitled by John Cadamore, on Flickr
Damn that’s a very nice set up you have. What does your car weigh?Not an a body. 70 Challenger 440 stock steel crank, srp flat tops, ebay h beam rods. Heads are pro comp rpm copies, home ported. Howards 272 at .050 and .662 lift solid cam. 4.30 gears, 29.5x10.5 phoenix slicks and 5000 ptc stall. 1.42 60' 6.49 at 105.8 on 91 pump gas
Well it seems to work pretty good to me. I think the Indy EZ heads were a little to big for my 440. I bought them to go on a 511 stroker build I was going to build. Well that feel through, so I decided to use them on the 440. Also at the time I only had a 9.5 inch 4200 stal converter. Again used what I had at the time. But I used of had a 8 inch 5600 one. Which I ended up installing one but never got to try it out before I sold the car.mopar 65. car weights 3455 with me. Figured I was way over cammed, but it worked.
View attachment 1715248657 Not a A-body. 64 A100 van, 496 lol deck, Edelbrock heads,637 comp roller,glide,bte 8”, Dana 4.88,32x14,2750#. 6.02@111
It ran good74 dartsport little 3000lbs at the line
408 Indy max heads from imm engines
12.5 compression
Indy intake e85 Holley 950xp
Solid roller
904 5000 convertor
Dana with a 4.56 and a 28 inch tire
Haven’t ran it yet
10.49 1/4 computes to a 6.73 1/8all steel 73 Dodge Dart weighed 3520 with me in it. raced on 93 pump gas
0.030 over 440 with wisco flat top pistons. 10.9 compression
eagle rods
Indy EZ heads with the valve bowls touched up.
comp cams solid roller 0.0264 at 0.050 and 590 lift
crane 1.6 roller rockers
weiand Tunnel ram, 2 Holley 750 DP carbs
727 with 4200 stal 9.5 converter
8-3/4 with 4.30 gears, I blew up the 4.10 I had in the car on the 4th pass. so I installed a set of 4.30 I had laying around.
M/T 275/60/15 ET Drag radials.
my car wasn't really set up for 1/8 mile racing and felt like it would of been faster with another set of 4.10 gears but sold the car before I could find out. with the wrong torque converter and very little tuning. the dart ran 6.70 at 102 in the 1/8 with a 1.48 60 foot. with my friend that weighs a 100 pounds less then me, the car ran 3 10.49 in the 1/4 at almost 127 mph. but I forgot what the 1/8 mile was. man I miss that car.lol
