post you 1/8 mile combos
racing340
Member
Leicester NC
Everyone has quarter mile combos how bout 1/8 mile combos?
right now 7.99 at 91 mph with a 1.80 60ft time spinning:D hoping for 7.70s or 7.60s soon
340 bored 30 over x heads stage 1 ported steal crank H beam rods 9.5 to 1 motor
Get your suspension dialed in, and you should be able to get a better 60ft and ET.
Here's mine:
904 manual VB
Dana w/4.10's
SS Springs
MP drag shocks in back
Competition Engineering front shocks
MT ET Street Radials 275/60R15
Times in sig
I keep mine set up for 1/4 mile, but I run 1/8 mile at my local track 95% of the time. The reason I keep mine set for 1/4 is simple....once in a while we have 1/4 mile races (like the Monster Mopar Weekend), or I travel to other tracks that run 1/4 mile. I don't want to have to over rev my car to compete...or worse, have to sit out a good race because my car is 1/8 mile only.
This is why I keep my car geared for 1/4 mile....Just my 2 cents.
410 stroker, pump gas, small solid roller, 750 carb, 727, 8" vert, 4.10 gear w/ 28" tire.
Times in sig.
1970 duster full body car just had the back seat removed (no weight there)
30 over 340 bme dome top pistons h-beam rods
comp cam 282sx 520/540 solid cam
j heads ported 245/150 flow (forsale)
x-cale intake with 950 hp carb
mp dizzy locked out 36 timing
small headers 1 5/8 into 3" pipes and flowmaster mufflers
727 trans with rev valve body and 5600 verta(8")
4.57 gears with no snubber
28x10.5 slick
8gal cell and 1/2 fuel line to front of car
frame tied and mp long drag shocks
and ss springs 02/03
about 3200lbs
went 7.40 at 90mph and 1.67 60'
car would pull wheels and drop them and spin
needed some chassis work some where in the combo..
i think the car had a 20 in it at lease.
sold motor to a member here....:hello2:
71 340 high compression with unported 587 heads, stock lift hyd.cam duration unknown , iron thermoquad intake, with thermoquad carb , 904 tranny with some good stuff , 5200 verter , 8.75 rear with 5.13 gears 1.43 60 ft.
[ame="http://youtu.be/ZH_o6hUge1I"]http://youtu.be/ZH_o6hUge1I[/ame]
My friends low compression 73 340 with same set up
[ame="http://youtu.be/KPpLJFkRdEg"]http://youtu.be/KPpLJFkRdEg[/ame]
71 Valiant 416 indy heads bullet solid roller 4spd 833 trans 4.88s 29.5 M/T
1/8 track I ran a 1.43 60' 6.58 @ 107.65 mph ( Air port )
1/4 mile track 1.40, 1/8th 6.32 @108 1/4 9.99 133.8 (Also Air port but better track )
well here are my slant times with the 4.86's and running 1/4 mile track (shooting ducks though)
1/8 mile split
1.91 60 ft
8.98 @ 75.41
1/4 times
1.91 60ft
14.25 @ 91.8
[/IMG]Its a full car and a everyday driver. 360 .30 over stock eddy head air gap intake and 6 inch drag radials 60 ft 1.96 1/8th 8.43 84 mph
My setup is 440 509 cam stock 452 heads m1 intake tti headers ptc 9.5 covertor 4.56 gears 7.70s at 86 mph 1.68 60 ft with some tunning it should run in the 7.40s
I want to know how 7172 Duster and his buds are launching so strong! Those are very good 60 foot times. I am using a 3.91 and what are probably stock springs. Where would you guys look for improvements in the launch. Oh yeah, the converter is about 2200 RPM but works well on the backroads I drive at 45-50 MPH at 2200-2500 RPM so I would rather not change it.
Besides, I won't be putting in bars and the car is already too fast.
I want to know how 7172 Duster and his buds are launching so strong! Those are very good 67 foot times. I am using a 3.91 and what are probably stock springs. Where would you guys look for improvements in the launch. Oh yeah, the converter is about 2200 RPM but works well on the backroads I drive at 45-50 MPH at 2200-2500 RPM so I would rather not change it.
They have 5,300 converters with 5.13 gears going thru the traps in the 1/4 mile at 7,400 rpm
OK then, it's the converter. Nice launches but not practical for a fast street car. Thx.
A car is never to fast lol
1970 dodge dart
3360 weight
.030 340 trw 13-1 compression
ported j heads 11/32 valves 2.08 1.625 flow 258/180@ .550
solid ft racer brown 324 dur .583 lift
273 mechanical rocker arms smith bros 3/8 push rods
stock forged 3.31 crankshaft
stock 1970 340 rods
holley strip dominator 850 dp
doug nash 1-1 fourth and a 5.13 gear 29.5x9 mt
super stock springs
best of 7.13 @ 94.75 with a 1.52 60'
have ran 1.50 60' but the tires are going away
[ame="http://youtu.be/kvG8ArRiJvY"]302 Found[/ame]
72 duster,340 low comp 240 hp.jerico trans, stock int and T.Q carb,stock lift hyd cam, 5.57 gears, dana 60, 1.49, 60 ft, 7.16 @93.67 in 1/8 mile
70 Dart 3000# 440 RV motor 8.5 comp 516 heads with mild port 2.14 1.81 valves .590 MP solid 4.56 gears 3800 coan foot brake 9x15x30 tires Best time 7.04 98 mph 1.50 60 ft
71 Swinger, Times & car in sig. with video, on a 125 ran 7.4s @ 95, no good video on that.
Stock bottom 360 magnum with 3.73s & 2800 stall, small re-ground roller., shifted at 5100.
Here's mine:
65 Barracuda, gutted, 360 with Hughes ported Eddies, M1 single plane intake, 750 Holley DP, MP .557 cam, Hughes 1.6 rockers, 904 with low first gear, 5000rpm stall converter, 4.88's in an 8 3/4, 275/60/15 M&T drag radials, cal tracks, QA1 9 way shocks. Best 1/8 to date: 6.94 at 96.79mph, 1.455 60ft
Ryan it is a ladderbar car with a 750 Holley street HP I also run ProParts headers.Just ordered a Tranzact ultimate brake for it.You can make those smog engines run.
what kind of suspenion u got and intake and carb
My 1/8 mile combo: A pissed off bull chasin me..
i mostly run 1/8 .
493
3300 w/ driver
eddy rpm heads
hughes flat tappet
4500 stall
T-brake
10.5 -29.5 hoosier
4:10 gear
ss springs
