66DartSedan
Hey what gauge wire is this?I did the external voltage regulator like you did on my cuda too. Made one from electronic parts.
Any chance you can post the parts needed to build the regulator? Saw it somewhere but can’t find it...I did the external voltage regulator like you did on my cuda too. Made one from electronic parts.
I found this one: Early A-body Instrument RegulatorsAny chance you can post the parts needed to build the regulator? Saw it somewhere but can’t find it...
Thanks guys. My AX-15 isn’t machined out for the speedometer gear and since our 200 has gps in it we never used the Garmin anymore so I decided to see what I came up with. The high beam indicator was just a brain fart I had one day so I decided to run with it!
The only down side is it sometimes takes the gps a little bit to find satellites to know where it’s at, when you start it up.
I decided not to put my tach in the dash either. Here’s how I did mine.My original plan was to use a Garmin too. After seeing it, I wish I had. I just went with cheap Equus gauges and a Speedway motors electronic Speedo. I was torn between putting the tach in the dash or not. I chose not so maybe I'll regret that. I' just refinishing it now. It will stay black but may have a silver trim ring. Not sure yet.
Cley
This photo is before I broke it trying to enlarge the indicating light holes. I' almost back to there now.View attachment 1715140120
I also decided to move the wiper switch. I feel it's better here.
the dashNot in the car yet, painted the bezels the same color as the car
I put my tach on the dash where it is because every really cool car i have ever known personally had the tach there. I've had some with the column mounted tach and always hated that too. I just moved this one from the column.
Cley
Tell me more about the chrome paint pen and your source. THXMy 69 383S dash before and after,It's spray can and dyed pad, chrome penned and pre-cut wood grain overlay, I had already butchered it for a tape player 35 yrs ago, so I installed the CD. Still working on it.
