Doosterfy
I'm considering building a 360. I don't want a stroker, I want to stick with a stock 360 block and crank. All I want to know is what are the power and RPM limits of the stock 360 block and crank, both LA and Magnum.
First question. How much power do you want or how fast do you want to run?
Need that info first.
If you have to worry about the limitations of a small block, maybe you should go big block.
I ave a 440 in the car now. It runs mid 11s@116 and is 100% streetable. Pump gas now power adders. You can see it on YouTube, my channel is Doosterfy. I'm going to be building more engines and using different transmissions and I want a stock stroke 360 in my engine collection. I always loved 360s.
If you love the 340 you'll love the 360!!
If you love the 360 you'll love the 340!!
Well, you're going to have people say that they've pushed 700 on a stock block with no problems, and others who will say they cracked a block at 450, so it's really a crapshoot. I'm over 500 on a stock block, and want to eventually put it on the bottle. If I crack the block, it will be a good excuse to get a better one, if not, even better.
Nope Iike 360s better than 340s.
Avoid the temptation of an Eagle crankshaft.
Good point as usual moper. I definately don't want race heads or a stroker crank. I'm thinking with the compression I'm talking it would be able to run on pump gas. Just a common sense engine that uses the stock block and crank to their fullest potential with out going crazy on anything. If the heads I'm talking about do not reach the limits, so be it. Also going to run a manual trans behind it, either an A-833 with a Gear Vendors overdrive or possibly a Passon A-855 5 speed overdrive. I'm figuring a combo like this should run low to mid 11s and be super fun to drive.Honestly, given your head choices... Unless you plan to go with high quality full race porting and a race-type solid roller, and build it as a full race engine, and you can stay out of any detonation issues - you're not going to reach near the breaking point of the block with a good set of caps. You don't make 1.6 or 1.7hp per inch out of a stock stroke with a "Stage II"-type head and a roller cam with .550 lift.
:violent2:
Lol...
But really not this again. Do an actuAl search, whole thread about the 600hp limit. I have a friend going 124 in 1/4 with dart and planing more. Another person making 900wheel hp with stock block and crank turbo. Search.
What's the issue with Eagle crankshafts?
