73NorthernDuste
I picked up a good federal pump with a bracket and integrated cooler today, but I still need the two triangular brackets that attach the pump to the block. It's a small block set up. The smaller of the two brackets has 2 45 deg bends and goes at the back of the pump. Even if someone has the other larger triangular bracket that they can throw in their scanner and email me an exact size picture of so I can make my own would be helpful since it's just a triangle with three holes in it. I think the saginaw uses the same two parts to bolt to the block so these should work too.
I have attached a picture with the parts I need.
Thanks
Brent
Thanks
Brent
