Joey N
Anyone know about this crank I still don’t understand it I can’t find anything on 318’s with a CFD on it
Okay I don’t know why I didn’t spin it while I had the pan dropped I’ll try and do that tomorrowprobably just a foundry mark.
the # cast or stamped into it is the one you want to use for ID
That's was an excellent article. Thanks!Generally if you run a top end (heads cam cr intake etc..) that can support 460 hp you'll make about 460 hp. Obviously there's a little more to it then that.
Here's a 477 hp 318
https://www.hotrod.com/articles/0901phr-mopar-318-magnum-engine/
Cast crank if in good shape will handle 98% of the builds planned for 318's out there....Haha it’ll do I guess
I’m using 1966, 273 closed chamber heads. Still reasonably priced, yet a big upgrade! Port them, port intake, mild cam, roller rockers it may surprise you…The biggest problem with the 318 is the stock heads don't flow well.
You are correct I was just thinking of a stroker crank but I don't need to deal with any of that I just need to hurry the F*#k up and get this engine done and in, whilst learning as much as possible.Cast crank if in good shape will handle 98% of the builds planned for 318's out there....
Maybe Ill keep the 675 heads currently on the motor and **** around with them and learn how the heads work and use them as learning material
plus they ain't worth much at all
Go to you tube and search the name “Charlie Servedio” who has done two different head casting of the 318 from a basic start to a full porting. You can follow along with his videos and do your best to mimic the work.Thats awesome and I hope to figure it out as well as you have, But Im willing to learn and soak up all the info I can because for the last 3 years Ive been on the forum even before I Made my account just learning and Im glad I can finally get my hands dirty. And maybe even learn to do little head work techniques.
There's also a point where you can have too much velocity, people always seem to view it as more the merrier when it comes to velocity, not the restriction (pumping loss hp) that smaller ports, valves, carbs, exhaust etc.. Very high velocities can become.Also port velocity is a big thing as well.
You don’t get the quench on dome pistons as With a taller flat piston. Also port velocity is a big thing as well.
Fill the chamber with valves. You have to have a lot of mechanics to open them though.If you want Coyote type power out of the 318 your best bet would be to build it to the specs of the 70’s T/A race motors, which were 305’s, mopar destroked the 340, but you could do similar with the 318. This would bring the power up to the 4-7+K RPM range, depending on the cam. Not very practical for street driving.
As others said not apples to apples comparison. A more apple to apple would be the Ford 4 cam or Cosworth DFV, with are both 60’s tech, gear driven 32 valve OHC, with 500+ HP from about 3 liters. This is where some of the tech for the coyote stems from. But way out of reach for the average person.
Ok you’re the man!!You can get quench with an open chamber head. That’s ridiculous
Ok you’re the man!!
