[FOR SALE] Proform spun aluminum 14" air cleaner assembly
rmchrgr
Skate And Destroy
Stamford, CT
For sale is a brand-new-in-the-box Proform air cleaner assembly. Drop base, 14" diameter. This is a brand new part, no run time. Mounted on top of my carb for about a minute, removed and put back in the box. Comes with new filter element and mounting hardware in two finishes, black and chrome. I will throw in a 1/4-20 rod for a carb stud. This is a really nice air cleaner, very light. Not your generic parts store air cleaner.
$55 + shipping. I take Paypal but however you do it, gift or otherwise, make sure the total ends up being the agreed upon price, no less. Money order is fine too, I usually ship next day. PM with questions. Parts are located in Huntington, NY, 11743.
- Greg
what is the distance from where it sits on the carb to the top of the lid?
If I am measuring correctly, it's 1.625" or 1 5/8". The base drops 2 3/8" and the filter element is 3". Hard to tell exactly though because the boss where the carb stud goes through is lower than the section that bulges up.
I know I can close my flat hood with it on the carb. and I have a high rise single plane. The drop base gives it a lower profile.
did you put it together and stick a tape in the carb hole up to the lid? bb under a flat hood is tight.
Yep.
Maybe try this if you haven't; put a string across the engine bay, tape it to the fenders, pull it tight. Then, measure down from the string to the carb base to see how much room you have.
