I made a major haul on CL locally today!
Guy was selling the core of a 77 Mustang II.
I bought the entire frame, with hoops over rear wheels, plus narrowed 9" rear end with axles,, ladder bar suspension, sway bar, and rack & pinion steering setup + a set of Quick Trick wheels, 15x3.5 in front, 15x14 in rear, for 400.00 bucks. !
First measurement says the rear end is about 4 inches wide overall, so decisions will have to be made. I haven't decided if I want to cut the 9" down, get the axles splined, and run it, or sell it, use the proceeds to have the C body 8.75 cut down, and buy axles. The 9" doesn't have a center section. I have a center section for the 8.75, but it is 2.76 ratio, which probably will not work with the steam roller tires that will be needed to fit the 13 or 14 inch wide rear wheels. If I go this way, the rear seat is definately gonzo...
I am trying to decided if I want to brush the wheels to give them a Centerline type look, or powdercoat flat black. Part of me really likes the flat black idea...
Now, the pictures....
