cody.bourgeois
Not yet. I bought the qa1 coil overs, its sitting pretty low. May just scrap the air ride.Btw, have you decided wether you’re gonna use coilovers or figure out how to get the bags to work?
That makes me sad. LolNot yet. I bought the qa1 coil overs, its sitting pretty low. May just scrap the air ride.
I’m wishing someone would do air ride with an HDK and figure out what all’s needed to make it work, so I know I have that option without doing all the leg work.
Time to break out the cocktail napkins and start doodling?the challenge is simple....there is no friggin room. We push the limit with the 3-1/2" od coil spring. combine the A body Mopar frame rail width. IF you could put a slim air bag in, there is bound to be rubbing....then come the blowout....then you are a hot sucker.
Would deffently need a Notch cut into the frame. I may work on it a lil more.Time to break out the cocktail napkins and start doodling?![]()
So what were the upgrades?
