Well I've been looking for a rattle can color that is close to my Darts paint. I was thinking it might be cool to use on some suspension stuff,but this can of Tremclad hammertone isnt close at all. The search goes on...
This pic is a test panel I sprayed and the edge of the drivers door. Not even close.
Here is the blasting cabinet I built using scrap components.. Used it yesterday and it works great! The legs are too short,not enough light,sleeves are too tight,other than that it's fantastic! Sure beats sweeping up sand.Plus I recovered almost all the media,and the stuff I didnt get back is still in the cabinet! Also want to double the view window size.
Light was easy to solve,my 500 watt halogen lit things up nicely!
I recycled a couple of old fridge shelves and use them in the cabinet!
Sand simply drains out the bottom.
This vacuum motor I recycled from a self inflating air matress that had a bad leak. Couldnt find the leak. I use the motor for dust control at the end of blasting. It clears all the dust out in a minute or so.
