Well I haven't done alot fo work but I did get some stuff done on the weekend.
I seam sealed most of the tubs on the inside of the car. Still have to do the outside and inner wheel wells.
I then put down a good layer of POR15. I'm not even sure I'm going to keep the spare tire area as I might go with a fuel tank that drops in through the trunk.
I've still got to do the inner quaters with POR15. I also have a few holes to weld up as well as tack the trunk hinge braces back to the tubs.
Riddler
Here I show you how bad my welding it. While I penetrate the metal, I don't have a nice clean weld.
Riddler
