Thank you Stew... I'm happy to say its a garage build and I hope to be able to continue.
Riddler
Thank you HemiMark that means alot. I've been having a hard time finding the time to work on the car but I've managed to get an hour here and there. I'll be making an update tonight from the last couple of weeks.
Riddler
... I had to clean every thread. This is slow and tedious work. ... The driver's arm had some media dust in it and while threading the heim joint in I managed to gall the threads. ... This part is garbage! ... Now just remember each bolt hole and such had to be cleaned of powder. ...
In all honesty Leanna he did use silicone plugs and the fiberglass tape, I was there and assisted. In fact I blasted all my own parts, taped and put the plugs in. Being a perfectionist I chose to clean the threads and such as id prefer spending a time instead of having cross threaded bolts and issues when i do final assembly. Anyone who has parts painted, coated, anodized or anything else should have the threads cleaned up.
I find Jeff's Powder Coating the most reasonable cost effective coater I've ever used and this isn't my first car I've built.
Riddler
Thank you sirelan67. Those can all be welded up tight.
How's about 6 and 7 on the left side?
Riddler
