A Body 440 WHY NOT Well-Known Member Joined Sep 28, 2019 Messages 361 Reaction score 143 Location Jersey Oct 14, 2019 #1 I have a SB crank and water pump pulley. The bolt pattern for the crank pulley is the same as my RB. Will SB pulleys work on a RB ? Thanks ,
famous bob mopar misfit Joined Aug 14, 2011 Messages 20,641 Reaction score 9,690 Location okla Oct 15, 2019 #2 A Body 440 WHY NOT said: I have a SB crank and water pump pulley. The bolt pattern for the crank pulley is the same as my RB. Will SB pulleys work on a RB ? Thanks , Click to expand... If diameter and bolts are the same , and u can get them to line up for the belt , why not ?!
