FlDart360
No, I just was surprised to see something other than a 5/16 pushrod, and was curious why someone might do such a thing.Are you thinking about a change because of noise? is there a problem?
Wow, 53% less deflection from what appears to be a small increase in diameter and wall thickness. That speaks volumes.""Is anyone using the 5/16" (heavy wall, Manton Grade 3 or Manton Grade 5) pushrods on solid roller valve springs (220lbs/540lbs) for reference?""
I just got a reply from Manton on which size of pushrod they would recommend for a spring spec of 230lbs/540lbs, @ apx 7.850" long and 6400rpms. They recommended their 5/16" x .118" in a 5 series [275k psi], or the 11/32" x .120" in the same series would deflect 53% less under the same load.
More room. The cam i ran those with was actually 699/672
Pushrod weight isn't a factor. The bigger diameter pushrod doesn't weight as much of a percentage heavier as you would think. And its way more than negated by the stability it creates.
In short, in any performance application, jam in as big a pushrod as will fit
Is there an issue of harmonics then?
Yes. Pushrods flexing will induce every manner of harmonic you can think of. I’ve seen it make an oil filter unscrew and fall off.
