I give up.
I give up.
I hear ya... It sucks when the "Tech" guys can't give accurate information when you order parts...
If you do what #2 said, then subtract 5/16" from the measurement. The point is to get to the type of measurement that the first guy told you: tip of ball to bottom of cup ==> effective length... for SOME manufacturers.One tech guy at Summit said to measure to the bottom of the cup to the tip of the ball on the opposite end...
Tech guy #2 said to measure the push rod with a 5/16" ball in the cup and go from tip of ball to tip of opposite ball....
You gotta look at the manufacturers specs to see how they spec them. Forget a distributor's data: go to the manufacturers data sheets. In the case of Comp, you have to look at their comprehensive catalog. For the 7821's they list the length as 'overall length".
I said that because I have recommended several times now to measure with a checking pushrod, find the correct length with that, lock it down, send it to Comp......or whomever and get THE RIGHT LENGTH pushrods made.
Continuing to order more pushrods without measuring only increases your chances of getting what is it? 4 incorrect sets of pushrods?
There is only ONE way to do this with a 100% success rate and measuring is it. Any other way and you are simply guessing.
I completely understand. I have gotten in a hurry before myself on projects, but it has never paid off. Yall might luck up and guess right. But, you have three incorrect pushrod sets now. IMO, it's best to go ahead and take the extra time and get it right, 100%.
Either way would work; the cutting up and threading of the old one would be a very good idea. Put a coupla lopcknuts in it, and away you go.I'm half tempted to find an old push rod and cut it and put some threads in it to check for length...
Or I could use one of Eddie's $10 each ones for the "mock up".... (It would also be cheaper than the $20 "checking push rod"....)
For T/A's.....Get a pushrod from a slant and a chop saw. Grind the ball end out and reduce the OD of the slip joint so it will just stay in the tube. Start trimming the open ended pushrod until you get the right length.I sure hope so since Mopar made a pile of um.
Yeah you are right. I don't know what the hell I was thinkin. lol
Here's the latest update:
We did get a measuring push rod and measured each 5 times to get a good average length. We ended up needing 7.058" from cup to ball.
We ordered a set, and they came. We measured them to be average of 7.064" +/- .005" from cup to ball and installed them....
We installed them today and have about an average of 1 1/2 threads below the rocker arm with the Comp Cams replacement lock studs/nuts for the rockers:
are those adjustable rocker lock nut faces machined?
Who did those heads, K.K.? Nice work!Here's the latest update:
