I have manifolds, so, yes, the column shift linkage works. Clearance with headers remains to be seen. I think the brand of gauges that the local parts store uses is Equis.
HemiDenny - Thank you, sounds like sage advice I will take and use. Thank you for taking the time to explain, very nice of you. Also, if you ever need someone to "test" any of your product, I can send my address - I am a fan of your work and products.
CP
I think you are heading down the Milodon road! And that has enough controversy all by its self. We actually have a thread on here somewhere over the merits or lack there of on Milodon quality. I can only speak to my personal experience and I have several Milodon oil pans with no issues. But if you want to poke a Bear that is a great topic!Are there any factory oil pans that work with the QA1 k frame? I am curious about whether the car oil pan sump (front sump) would nestle in between the cross tubes.
I was looking at it and wondering the same thing.I have seen one or two instances where individuals have relocated that front bar.....
on the speedhut fuel gauge I had to set mine manually was having same issue with stock sending unit. Follow the manual instructionsA little progress. I purchased a dash pad from Ebay and used Herb's Part to match interior color (F5 Dark Green). The color was spot on and wonderful to use. They make some claims about runs, drying etc, well they are accurate.
Also installed the new gauge cluster and SpeedHut gauges. These are very cool and enjoy the setting for warning, shift light etc.... Only issue I have is the fuel sender. I am not sure if I have wrong ohms, or set up the the sender in the tank incorrectly - Swap Drama - but will get worked out.
Next step is interior. The interior is F5 green, so trying to keep it as original as practical. I have seat covers coming for buckets and rear bench, should be here next week?
As for the Hemi Swap, it is in and generally tuned. I have fans, tach, idle etc set up. Idles at 850rpm, has 60+/- oil pressure and fans turn on/off appropriately. I loaded a tune from another Hemi swap (same year and type, but different cam. This motor has the 6.4 Manual Car NON-MDS cam).
