Hey guys, any ideas on what i can do about the distributor vac advance hitting the tunnel ram?View attachment 1715367476
hahaha i suppose i could do thatSince you've got a right hand drive, and the water goes down the drain backwards where you are, how about you turn the dizzy 180* and swap the wires?
Disagreed! those spacers are called "badass!"The spacers are velocity stacks. The distributor can be clocked any way you want to make the vacuum can miss the intake manifold. The top is on correctly when the slope of the carb pads is down in the front. Just like you have it in the picture with the distributor. So that is correct.
This is going to sound silly, but what will happen to the firing order by moving the oil pump drive?Remove the distributor and ether rotate the rotor 180*’s outa d then re route the wires accordingly or move the oil pump drive with a big screw driver. With the large flat top screw driver, stick it in the pump drive as if removing the drive but just keep rotating the drive a number of teeth u til the distributor clears.
ok cool i'll try it out soon thanks!Just turn the gear. It doesn't affect the firing order.
And I'd reconsider not using the vacuum advance. I'd use it.
I can't spin it 180* as the vac adv hits the firewall.
Also, is it possible to actually remove the vac adv unit all together? It doesn't get used anyway.
Hello all, just wondering if there's a throttle cable bracket available for these tunnel rams? Any help always appreciated thanks.
Ps. i think i have rectified the vac advance issue.
