70Swinger
i have a question about strut rods, if they are bent would that cause my wheel to sit on an angle? or wut else could it be?
Thnx, Adam
Thnx, Adam
OldVart said:I would think you'd need quite a bend in a strut rod to cause a wheel to be at an angle. The left one on my Valiant had a good bend in it but it never changed the front end geometry so that it was noticable. Which wheel is at an angle, and which way - ie. in at the top, in at the bottom?
OldVart said:O.K. Is your strut rod bent on the passenger side? That would seem to be something in the main suspension: tie rod end adjustment, ball joint? Check your upper control arm bolts and ball joint VERY carefully. And, as mentioned, make sure your torsion bars aren't way out of wack.
